Using 5W-40 oil instead of 0W-40
I live in South FL so my car is never in a very cold climate. I don’t track my vehicle (at least at the moment) but I generally enjoy driving hard on the engine whenever it’s safe - so my car spends a lot of time in the higher rpm range. My 991.2 C2S currently has under 10k miles and I will be doing an oil change soon. I’ve read a lot of threads recommending the use of 5W-40 instead of 0W-40 in warmer climates. This raises a lot of questions in my mind as I feel that messing with manufacturer recommended oil requirements can be problematic.
What if any performance improvements will be noticed.What are the long term benefits of using 5W-40 instead of 0W-40 in a vehicle driven in warmer climates.- Does using a different oil than what’s recommended affect the warranty on the engine. I have a Fidelity Platinum plan which includes powertrain.
- Are there any potential downsides to switching from 0W-40 to 5W-40?
- Are there any issues with switching back and forth between 0W & 5W. So for example, using 0W in Winter & 5W in Summer? Or does switching back and forth potentially introduce other issues?
![](https://rennlist.com/forums/images/buttons/collapse_tcat.gif)
Popular Reply
01-16-2021, 10:06 AM
Received 5,404 Likes
1) None (won't effect, braking, acceleration, or handling)![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
2) No. There are 100s of Porsche A40 approved oils. There are 3 approved viscosities; 0W40, 5W40, and 5W50
3) None
4) None. And remember, 5W40 and 5W50 are good till -13 degrees F. Wen are you every going to see those low temps. Never!
3) None
3) None
3) None
The following 10 users liked this post by LexVan:
99-911 (06-21-2023),
991.1 Guy (01-16-2021),
997ajk (04-14-2021),
csrealtor1 (05-05-2021),
desmotesta (01-16-2021),
and 5 others liked this post.
3) None
3) None
Sajan (06-20-2023)
3) None
3) None
I switched from Mobil 1 0w40 to Liqui Moly 5W40 Leichtlauf for the last 2 oil changes and I've been very happy with it. I swear the engine sounds smoother, but that's probably in my head. I live on Vancouver Island, so think Seattle for weather and temperatures. I did a used oil analysis on my last oil change and all was very good.
The following 5 users liked this post by Wolpertinger:
320cap (01-17-2021),
981KMAN (01-19-2021),
Class5Kayaker (01-22-2021),
Scott O'Connor (11-09-2021),
voiceprint1 (07-13-2021)
I am disappointed that this did not turn out to be a typical Oil discussion thread
Kidding aside.. that goodness that there is consensus on what has been available information for a long time
Now, engines with tight tolerances are particular on oil viscosity. We aren't dealing with a small block chevy where the clearance for the rods are the grand canyon.
Once you switch to a thicker viscosity, the engine "compensates" for the thicker oil. Clearances become larger. Going to a thinner viscosity, there's a greater chance of limiting the engines life down the road. You'll burn more oil, there'll be less oil pressure, etc... Now, will you notice a difference between 0w and 5w? Probably not, but I won't take that risk, personally.
3) None
3) None
Why 5w40 vs. 5w50? I am sticking with 0w40 until out of warranty as my local dealers will not use 5w50 and I have zero confidence they will support a warranty claim on my behalf if I use 5w50 as it is not listed in my ‘19T owner’s manual. Seeing as how I only put about 3k miles annually on the car maybe I should just go with an indy, do it myself, and use 5w50....
FWIW, Mobil 1 5W-50 is a Porsche A40 approved oil, so I don’t see how it could be a problem to run it.
Robocop305 (11-23-2023)
