Gas smell after drive
If you only drive occasionally, drive for at least 20min in non sport mode to ensure everything warms up to highest temp in order to burn off water, un-burned fuel etc. in the engine after sitting
note, modern engines should not be idled for long period as the engine management will increase fuel to get cats hot which can result in washed cylinders.
I might try check the bulletin for my car. thanks!
