911 Brake Fluid Flush - How often?
Old 12-02-2020, 07:03 PM
Norge911
Norge911's Avatar
Checked Lexus ES and RX - 3 years for brake flush, spark plugs 60k miles or 72 months.
Mercedes brake flush same as Porsche but Mercedes is very aggressive with their differential fluid replacement. 2000k miles for first one if you have an AMG model
Old 12-04-2020, 02:47 AM
TwinTurbo420
TwinTurbo420's Avatar
Originally Posted by LexVan
Set aside your brake fluid for a moment. Why is your oil 2 years old? That's a bigger issue.
I change my oil every 1 year. I drive this car < 10K miles/yr.
Old 12-04-2020, 03:04 AM
TwinTurbo420
I don't think any of this kind of stuff is listed in the Owner's Manual. These things are listed in a separate thinner booklet dedicated to Maintenance Schedules and a place for the dealerships to put their service stamps. Maybe yours is missing? If it is, they are easy to pick-up on eBay.
Yes, I have that booklet & I have read it & highlighted & marked it up & created a document on my computer for my planned C2S maintenance. But, I just looked again & Eureka! there it is hidden on p. 10.
“Additional work” written 90˚ on L side of page! It DOES state change brake fluid every 2 years.
IDK WHY Porsche did not list it in the section with work to be performed every 2 years or 20K miles, 40k, 60k, etc.
Old 12-04-2020, 03:13 AM
TwinTurbo420
Any thoughts on:
I have seen nothing re problems with brake fluid other than moisture content, which of course is an issue & the main reason to change it.
I have also heard that since brake fluid does not circulate, measuring water % at the brake fluid reservoir does not give you a true test of the moisture content at the calipers & elsewhere in the system.
Old 12-04-2020, 06:23 AM
LexVan
LexVan's Avatar
Received 5,413 Likes on 2,516 Posts
Probably so the brake fluid flush gets their own stamp in the Service Booklet.
Old 12-04-2020, 09:19 AM
GSIRM3
GSIRM3's Avatar
Originally Posted by 991carreradriver
This ^^^^ is only partially accurate. Brake fluid is hydroscopic (naturally attracts moisture). Overtime its H2O content as a percentage of fluid will increase due to ambient humidity. The brake fluid system is not air tight. The higher H2O saturation, the lower the boiling point of the fluid. If the fluid should boil as a result of heating the fluid through braking, the fluid becomes gaseous. The boiling process will create the gases and brakes will be compromised.
If one engages in regular spirit driving, track driving or similar driving it is advisable to change fluid every year. For example, I have taken readings of my fluid and ranged >1% but <2% H2O and found my brakes compromised (mushy) during heavy continuous braking. Brake fluid testers are good for information, but it all depends on the heat the system generates and the amount of H20 saturation.
This is the answer.
Old 12-04-2020, 09:28 AM
991carreradriver
991carreradriver's Avatar
Any thoughts on:
Correct, this is the reason that bleeding brakes between flushes is SOP with track duty.
911paul (11-06-2022)
Old 12-05-2020, 07:48 PM
TwinTurbo420
So, checking for water % @ the reservoir is virtually useless?
Old 05-29-2024, 10:40 AM
bbal
bbal's Avatar
Oops
Quick Reply: 911 Brake Fluid Flush - How often?
