LED gear display no P,R,N, only 1 thru 7
2012 991 3.8 S LED gear display no P,R,N, only 1 thru 7. Is this common? Where to start the search? Cluster - shifter...?
that's normal, the LCD block shows the gear number.
You should have the PRND/M stack I believe above the gear display with a little red LED indicating where your shifter physically is.
The red LED shows where the shifter is (drive, for example) and the LCD shows which gear the transmission is currently in (1, 2, 3, 4, 5, 6, 7).
