Ignition Switch Won't Accept Key
Old Nov 7, 2020 | 07:42 PM
jms911's Avatar
jms911
Unhappy Ignition Switch Won't Accept Key
I have a 2012 Carrera S with PDK. When I attempted to start my car, the electronic key would not slide into the ignition switch on the dashboard. Neither my primary or spare key would work. I tried jiggling the PDK shift lever (currently in "PARK") and turning the steering wheel (steering column is not locked so wheel turns both left and right) but nothing seemed to clear the issue. Key is communicating with car - locks and unlocks doors and sets alarm normally. I tried disconnecting the battery then re-connecting but nothing changed. Since car is locked in "PARK" I cannot roll it out of garage to get on flatbed tow truck. Is it possible that the switch is worn and that replacing the ignition switch will solve the problem? Would that require reprogramming of the keys?
UPDATE: This issue has been resolved. I determined that the key was removed from the ignition switch without the switch being turned all the way to the left - "OFF" position. After some gentle jiggling of the mechanism, I was able to turn the switch completely to the left. Now the key can be inserted and removed normally.
Last edited by jms911; Nov 9, 2020 at 02:45 PM. Reason: Add update for resolution of issue
Old Nov 8, 2020 | 06:56 AM
Fullyield's Avatar
Fullyield
Your owner’s manual describes the procedure to manually unlock “Park” so you can roll it out of garage for a tow truck.
Old Nov 8, 2020 | 08:38 AM
LexVan's Avatar
LexVan
I'd bet donuts to dollars you need a new battery in your 2012. Has it ever beeb replaced?
Old Nov 8, 2020 | 08:41 AM
LexVan's Avatar
LexVan
JMS911, this thread will help you. Regardless, if your battery is original, it's due. Good luck, and welcome to Rennlist:
https://rennlist.com/forums/showthre...errerid=130056
Old Nov 8, 2020 | 09:25 AM
barncobob's Avatar
barncobob
if it has original battery, thats the problem like lexvan said
Old Nov 8, 2020 | 01:16 PM
jms911's Avatar
jms911
Yes - it was replaced by my indy mechanic on 18 March 2020 so it's been in service less than 8 months. I have a charger on it now - indications are that the battery is a bit low so that might be the issue.
Old Nov 8, 2020 | 02:45 PM
Jack F's Avatar
Jack F
If you get the car started, have the battery checked right away. If it’s failing, then have them warranty it.
Old Jun 29, 2023 | 06:13 PM
Eg3's Avatar
Eg3
This happened to me the key came out the ignition before the car was turned off now I can’t turn the key. Did you have to do anything special to get it back to the left. I tried a bunch of jiggling and it didn’t work
QUOTE=jms911;17011550]I have a 2012 Carrera S with PDK. When I attempted to start my car, the electronic key would not slide into the ignition switch on the dashboard. Neither my primary or spare key would work. I tried jiggling the PDK shift lever (currently in "PARK") and turning the steering wheel (steering column is not locked so wheel turns both left and right) but nothing seemed to clear the issue. Key is communicating with car - locks and unlocks doors and sets alarm normally. I tried disconnecting the battery then re-connecting but nothing changed. Since car is locked in "PARK" I cannot roll it out of garage to get on flatbed tow truck. Is it possible that the switch is worn and that replacing the ignition switch will solve the problem? Would that require reprogramming of the keys?
UPDATE: This issue has been resolved. I determined that the key was removed from the ignition switch without the switch being turned all the way to the left - "OFF" position. After some gentle jiggling of the mechanism, I was able to turn the switch completely to the left. Now the key can be inserted and removed normally.[/QUOTE]
7 Porsche Models That Have Aged Like Fine Wine
Old Aug 17, 2023 | 02:01 AM
bhunter's Avatar
bhunter
Default Ignition Key can't be inserted
Hello from Richmond Va
I have a similar but different issue ... nether of my key's can be inserted just about 3/8 inch into the ignition switch and the steering wheel remained “FIRMLY” locked in place.
The partially inserted key can turn the switch to the right and left but doesn't engage the starter nor release the locked steering wheel.
Observations & misc...
The battery is charged and the window drops when the door is opened
the display shows Mileage, speed, time and the radio lights up and operates, remote door locks
What doesn’t operate…
Windows, top, mirrors & horn
2009 Carrera S, 49,000 mi Convertible
Any suggestions would be greatly appreciated
Bill
Richmond Va
Old Aug 17, 2023 | 10:08 AM
duxsi's Avatar
duxsi
Bill
Richmond Va
@bhunter
You may want to post your question in the 997 forum.
https://rennlist.com/forums/997-forum-113/
Old Aug 17, 2023 | 10:32 AM
Viper1000's Avatar
Viper1000
I never take my key out of the car.....just the fob.
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
