There have been a few threads lately around pads for the 991.2 base/T model and I had recently spent some time doing some research of my own and thought I would share what I found (for iron discs). I had been told by some folks that there were no after market pads, which I knew to be complete BS. I am attaching some measurements - this came from Endless, which are the pads I bought. Pagid seems to measure almost exactly the same. Note that with each manufacturer there are multiple compounds that will work so you can use these part numbers to get the right fitment and then choose the compound.
Please add pads that you have confirmed work on our vehicles.
Endless
ME20 - track oriented pad
Front: EIP193
Rear: EIP218
Total cost: est $770 for a full set
Pagid
RS29 - track oriented pad
Front: 8074
Rear: 4909 (Suncoast has 4918; need to confirm)
Total cost: est $840 for a full set
Ferodo
DS3.12 - track oriented pad
Front: FCP4805G-N
Rear: FCP4713G-N
Total cost: est $770 for a ful set
DS2500 - street pad with light track use
Front: FCP4805H-N
Rear: 11 FCP4713H-N
Total cost: est $530 for a full set
I think the Pagid rear are 4909 as that is the combination I had on my T
Ferodo are correct.
Interesting - suncoast has the 4918's but if you used 4909 then that must be correct. 70mm height makes more sense to me (4909) vs 64mm (4918). I'll update
