PDK Calibration
So I had the PDK service at my Indy last week....wow, what a difference! Shifts
are clean and crisp again just like it used to be. I guess I didn’t notice until we bought the Macan S two years ago and noticed the shifting difference. That always stuck in the back of my mind, so the time was right as I needed brakes as well. I also upgraded to an aluminum finned pan which was the same price as the plastic OEM from Porsche....granted, didn’t need to replace the pan, just the filter inside, but it was one of those “while you’re there” moments. Just like replacing the brake lines, pad clips, caliper bolts, etc. Just have to bed those pads...the rears squeal a bit, however, it’s just been 30 miles. Already did the “dozen” or so 50% braking from ~70mph (Sebro slots/Ferodo DS2500 pads). Just time.... |
How many miles were on it before the service?
"Calibration" is a bit misleading as a thread title FWIW.. |
What is involved in the PDK service?
What are symptoms of PDK trans behavior that point to PDK calibration needing to be performed?
Never heard of this.
How old is your 911 and how many miles on it? |
Just turned 47k miles. The PDK Service was a complete fluid change, new pan/filter (in my case), and PDK calibration. I called the thread PDK calibration as my Indy advised that just doing the fluid change won’t really be “noticeable”, but with the calibration I would feel it. He was right...calibration costs an additional $60, takes about 20 minutes. They hook up the PIWIS and do a series of key turns, press on the brake pedal, etc...the PDK makes a series of grunts and groans. Now it shifts like when it was new. Symptoms were that the shifts in Sport mode where I do most of my driving seemed a bit slow and downshifts with the rev match seemed a bit jerky. It’s like the frog and the slow boiling water, I just didn’t notice it. It was when we bought the Macan where I really noticed how crisp it was compared to the 911.
Doesn't the Cobb handheld tuner do the PDK calibration too? Or is that only those with the optional PDK software (vs. just ECU software) loaded?
Originally Posted by SoCal C2S
(Post 16949880)
Wonder if my new PDK didn't get calibrated and that's why it's so clunky when it's cold... |
Mine is no longer clunky when cold....just nice crisp shifting. There is a bit of a slight delay when cold however, but just slight. Best $400 ($800 with the new aluminum pan) I’ve spent....I would even call it a mod!
(Post 16951605)
Originally Posted by asellus
(Post 16951719)
Gaaah don't say that. Called my dealer today about ensuring the learn/calibration process was completed on my car and they said they could redo it, but I'd have to pay if there weren't any fault codes present.
The car learns your driving style and adapts the best it can to those parameter. “Calibration” is where the clutch plates are put through a process that realigns the plates and takes into account the wear that’s present and matches the alignment for the crisp shifting....of course there is always a limit to how much wear and alignment can be zeroed out. If others who are more knowledgeable on this subject can chime in....don’t want to lead someone down the wrong path. |
There are several posts that talk about PDK reset and user that have done, have given positive feedback.
https://rennlist.com/forums/panamera...procedure.html |
(Post 16952140)
There is a difference between “learn” and “calibration”. I think the way as to do the reset is a series of starting the engine for an amount of time with certain function switched off and then again with them on and at some time pressing the gas petal. (Updated this sentence to remove the battery cable removal as it does nothing). The next post has a link to another thread with the details.
Originally Posted by Gonzalo38
(Post 16952156)
https://rennlist.com/forums/panamera...procedure.html Regardless, I have tried this on my 991.2 and was unable to note even the slightest of change. If Autel doesn't get back to me by the weekend with confirmation of features, I'll be making a drive down to a buddy with a Autel MS906BT to see what functions it can run through. :\ |
Worth mentioning here, I feel
I confirmed with Autel that the MaxiSys Ultra and the 908 and up (909, 916, etc) are capable of initiating the PDK calibration. The 906, allegedly, cannot. I'll be testing that this weekend though. |
(Post 16954573)
