Code PO0069
Old Oct 2, 2020 | 06:00 AM
CoquidePR's Avatar
CoquidePR
5th Gear
Default Code PO0069
Hey guys, I have a 2013 Porsche 991 Carrera 4S with 33,056 miles. The check engine light came on with Code num PO0069 so I took it to the nearest Porsche dealer & they installed a new air flap solenoid, pressure sensor in the intake manifold, and new throttle body with new seal. after two week the code PO0069 came back on. So I replaced spark plugs, ignition coils, new k&n air filters and oil change. The code still there. currently the car is running however idle speed is 672 with a small but noticeable hesitation
Old Aug 9, 2024 | 11:37 PM
cmorales954's Avatar
cmorales954
You ever get this fixed?
