991.2 Winter tire size
Here is a doc that might help:
Approved Tires, Wheels and Wheel Spacers March 18, 2020
https://static.nhtsa.gov/odi/tsbs/20...77990-0001.pdf
maschinetheist (09-27-2020)
My winter set for my 991.2 came with the car on 991.1 wheels, 245 front and 295 rear.
https://static.nhtsa.gov/odi/tsbs/20...72077-0001.pdf
The following 2 users liked this post by bb964:
barrios35 (10-26-2020),
grim sleeper (09-30-2023)
my bad - here is the 991.2 Approved Wheels and Tires TSB
Does everyone try to stay at the same size as the summer setup or something more comfortable for winter?
Looking at 235/40R19 mounted on a 19x8.5 for the front and 295/35R19, mounted on 19x11 for the rear.
Was not sure if I should stay at the sames sizes.
This is what I did for my 991.1. Narrower wheels with a smaller diameter are better for winter driving. Makes it easier for the tires to cut through the snow rather then float on top, and the smaller diameter gives you more distance between road and rim to account for awful winter roads. Also, winter tires, which don't last long anyway, cost less in 19" form than 20". I've had separate winter wheels for several cars and always size down from the summer set. No complaints, aside from slightly compromised cornering ability, but I think that would be the case with any winter tire.
But -- although the 295's are a bit narrower than the 305's of the summer 20"-ers, they are still W----I----D---E, so don't think you are magically transforming the winter set to pizza cutters.
BGLeduc (10-26-2020)
Agree. I spec'ed my 991.2 GTS Coupe with 5 lugs and without RAS so I could fit the 19" winter set and change them easily myself. Put them on this morning in my garage, the forecast is for mid 20's later in the week.
