contents of front trunk foam compartment for 991 Carrera
In the 991.1 I believe the headlight adjustment/removal tool is in there. We don't have that on the .2 as the headlight is apparently actually attached to the car instead of held on with hopes and dreams or something.
GT3FZS (09-22-2020)
Yes, I have a 2015 991.1, and the contents of the tool kit are below. I don't know if the 991.2 is different, but that is what some people are posting above, and indicate that the 991.2 doesn't have the third, hinged item, which is apparently used to adjust the headlights only on the 991.1.
991.1 tool kit contents
WPO, thanks for the actual pic of the HL removal tool. Seems the 991.2 does not use that simple method, but probably another "over-engineered" solution that only a dealer can provide. I guess the good news is that I'm not missing this tool, but then again, how does an owner remove the HL if front bumper removal is needed for some reason. Seeing my indy shop on Thursday and will ask them and then report back.
Some missing holes are possible as variant versions of 911s (coupe with/without sunroof, cab and targa).
From my BMW experience, they had same tool box with same mold but different tool configurations between options/models.
So I wouldn't worry about that.
Neither my dealer or indy could confirm that a tool is supplied with the 991.2. Sooooo, not gonna worry about it for now. Anyone seeing this who has a 2018-19 991.2 who wants to confirm that there is no tool for HL removal in their tool kit; that would be appreciated and put this question to rest. TIA!
SFZ GT3 (09-25-2020)
Try page 284, or look under "Towing"
There are several diagrams showing you how to use the wedge to access the PDK selector lever emergency release.
