Inspection before warranty expiration - What to look for? Should I extend warranty?
So my recently purchased 2017 991.2 S has a factory warranty that is about to expire in about 3 months. The vehicle currently has only about 5k miles and was meticulously maintained by owner. He had yearly maintenance inspections including 10k and 20k servicing. Also, prior to delivery, the water pump was replaced under warranty.
I want to take the vehicle to an independent shop to have it thoroughly inspected prior to the warranty running out - this way I can have any discovered issues that would be covered fixed by the dealership under warranty. Given that the vehicle has such low mileage, I don't expect to find much if anything wrong that would be addressed as a warranty repair. I realize that it's not just mileage, but also time that causes certain issues to rear themselves, and this car is already nearly 4 years old.
What should I be vigilant about with regards to the vehicle inspection that might be failing and be covered by warranty? As I mentioned, the water pump was just replaced which I'm aware is a common issue. Anything else like that? Are there certain things that I should be asking the independent mechanic to look carefully/closely for?
My dilemma is that I have the opportunity to extend the factory warranty for 4 more years for about $4k, especially considering the very low existing mileage and anticipated mileage over the next 4 years. I'm not a HUGE gambler but I know my driving habits and style (no tracking or extremely aggressive driving) and I don't expect to put more than 5k miles per year on the car. I figure with my knowledge of the vehicle's prior service history which was impeccably maintained, followed by my own impeccable maintenance, I stand a good chance not to burn through $4k in repairs (outside of routine maintenance).
If you elect to go for an extended warranty, do not pay the crazy Porsche price. Search “Fidelity Warranty” on this site for lots of information. With your low mileage, you’ll pay far less than $4K.
DaveGee
DaveGee
I have found that inspections prior to warranty expiration, although necessary, are largely useless.
They usually only uncover maintenance issues, which may or may not be necessary, and usually you are aware of.
It is nearly impossible for these inspections to forecast an impending catastrophic failure.
Last year my wife's Mini Cooper S was coming off warranty. I took it to both an indy shop and BMW less than 1 week before the warranty expiration.
Neither shop found a single under warranty repair to be made.
Believe it or not, a couple of days later, exactly one day before the warranty was to expire, the timing chain snapped. Better to be lucky than good!
The $3k repair was covered, but still cost me about $650 in "while you're in there" replacement parts.
As far as your consideration of an extended warranty, it all depends on you risk tolerance.
https://rennlist.com/forums/991/1139...-warranty.html
yes all porsche dealerships honor fidelity claims. check out this thread for contact info for a couple people who can get you a cheaper quote.
