Is it safe to repair Porsche tires?
I got a flat tire in my 2015 911 Targa. The tires are Pirelli P-Zero. There is a small screw in the center of the tread on the left rear tire. I asked the Porsche dealership, and they said they can't repair tires, only replace them. Apparently, this is related to the "speed rating" of the tire. I decided, at least initially, to take it to a private tire shop. They seemed to think it was no problem to repair the tire. Is this a safe approach? I'd rather not replace the tire for $500 every time I get a flat. Thoughts?
The following 5 users liked this post by Bxstr:
Curvfun (07-28-2020),
ducktails (07-29-2020),
koala (07-29-2020),
Rich_Jenkins (07-27-2020),
Wrtflyr (07-28-2020)
I think an independent shop will say the same thing: they can repair it, but the speed rating is void at that point. The only caveat is if the puncture is in the shoulder area; no one will repair it at that point.
In retrospect, I was never really sure what that implied. Am I only good to 75mph? 90mph? Or, just 1 mph lower than the original speed rating. Murky. However, for normal driving it's fine.
I mean if you hit 150MPH for few seconds it won't generate a ton of heat, the issue with track driving is your tires are under A LOT more load for A LOT longer periods of time repetitively in one day. I wouldn't worry about your tire exploding for normal or even spirited street driving. If you are pushing your car to levels where you need to worry about a properly repaired tire on the street, you will face more dangers in harming others or yourself.
paddlefoot64 (07-31-2020)
It's only a problem if you are rapidly heat-cycling the tires (for example on a track). The rapid heat cycle causes stresses that can lead to catastrophic failure of the tire compound at the point of the patch or nearby.
For the road, it's just fine - just don't use a patched tire for track work.
cheers!
cheers!
These repairs are pretty effective, but I would personally take it to a tire shop for a proper internal glued patch for piece of mind especially as it only costs around $40. But I guess if it held for 4,000 miles. Meh.
The following 2 users liked this post by 991.1 Guy:
AdamSanta85 (07-31-2020),
KWP1911 (08-17-2020)
