brake light switch
Old Jul 20, 2020 | 04:17 PM
Zippy991's Avatar
Zippy991
4th Gear
Default brake light switch
Can anyone tell me where the brake light switch is located on a 991.1?
Apparently my stop lights come on randomly when I am driving. I hope it is only a switch.
Old Jul 20, 2020 | 05:10 PM
C4SJOHN's Avatar
C4SJOHN
Check this posting here on Rennlist it may help. https://rennlist.com/forums/991/1063...ake-light.html
Old Jul 21, 2020 | 12:25 PM
Zippy991's Avatar
Zippy991
4th Gear
Thanks for the response John but I am only trying to find out where the brake light switch is located. I do not know if it is mechanical attached to the brake pedal or hydraulic located somewhere in the brake hydraulic circuit. There are no warnings and the stop lights all go on when the pedal is pushed. The problem is that the stop lights also go on randomly without the brake pedal being pushed. I figure it could be a faulty switch (or just an adjustment if mechanical and if I'm lucky) but I don't know where to look.
Does anyone know where I can find the switch?
Neil
Old Dec 14, 2023 | 01:07 AM
fpb111's Avatar
fpb111
Top of the pedal. It snaps into a plastic socket and then gets pushed against the metal pedal arm. It is a proximity switch.
I am trying to find a vid showing duct remove so I can change my switch.
