How do the stock bypass valves operate on the 991.2?
#31
Sounds perfect. So you ended up using the BOV in place of the sound symposium valve, so it’s still venting from the pressurized intake but now into the line that comes into the cabin that previously was attached to the sound symposium? You also capped off all the old connections from the factory DV?
#32
Not quite. I’m taking the pressure off the ports used for the sound symposers and using those to connect to the blow off valves. From there it’s vented to atmosphere. I left the sound tubes open (could cap them if desired) and capped the ports on the inlets.
The following 2 users liked this post by polobai:
MingusDew (05-15-2024),
wkearney99 (09-16-2024)
