Squeaky PSE Valves
Squeaky PSE Valves
They squeak when they open and when they close. I pulled into the garage and turned off the PSE and heard a squeak. Of course, I played with it a few times, opening and closing them...are these the dreaded change over valves or is this something else entirely? do they require lubrication, beer, or something entirely else?
rnl (07-20-2020)
I just ordered off Amazon the WD-40 Specialist Spray Gel Lubricant. Good to 500 degrees. $8.74. I don't really think I need it, but, I don't mind doing it proactively. The vacuum valves are easy to see & locate right in the center (991.1) of the exhaust under the bumper.
koala (07-21-2020)
mnnn. I’ll check it out...ordered it. Thanks
Morning, RNL. Any update? I did mine about 2 weeks ago. I didn't note any difference, but, I also did NOT have any squeaky PSE valves. I only did it as preventative. The odor from the WD-40 Specialist Spray Gel Lubricant (very nice product, btw) overspray quickly burnt off, too, FYI
