What service is due on 991.1 GTS
2015 GTS
It was in a year ago at the dealer at 17.5k miles. Invoice says it got the following...
You can see what was done last time. “10K C PERFORM 1 YEAR OR 10 (Tech 675, 0) Complaint: GUEST STATES PERFORM OIL AND FILTER CHANGE Cause: PERFORM OIL AND FILTER CHANGE Correction: PERFORMED 10K SERVICE PER MANUFACTURE GUIDELINES”
Now a year later with 20k miles it’s due for a service. Dash says “interim service”
based on that information is it just due for an oil change? Or some other scheduled service and maintenance?
Thanks!!
Thanks!!
Interim is just a oil change and filters. I believe a few items are cleaned out (front air coolers, etc.) and the sunroof if applicable is re-greased. The major which is more expensive is a flush of brakes and other items I believe. For the interim you should be around $900-$1,300 I think as they always find a latch or a spoiler that needs a new part to work as designed.
2015 GTS
Thanks!!
Thanks!!
There was a thread about 20K service just a few days ago, good info there
Correct ^^. It’s time for a major due to time not mileage
shammerman (06-30-2020)
Basic Sponsor
A 20k service consists of oil/filter change, cabin air filter, and brake fluid. Additional service includes cleaning radiator and lubrication for hinges and roof sliders.
Thanks all...seems like brake fluid flush is part of this one as well. I always have don the dealer. They want $1300-$1400 for this. My very reputable Indy Porsche repair shop (does work on my other, older P-car) can do it for a lot less...Thoughts?
Basic Sponsor
As an Indy, go with the indy! For brake fluid replacement I'd encourage you to find a shop that does track prep or tracks their own vehicles as brake bleeding is something they will have a lot of experience with.
