Steering Wheel Code
Old Jun 10, 2020 | 03:40 PM
jfable's Avatar
jfable
6th Gear
Default Steering Wheel Code
Hi guys, I had an independent shop replace a steering wheel sensor to get rid of a bunch of error codes.
Problem is, they didn't have the right equipment to reprogram the steering wheel properly. Paddles don't work, nor does the select lever or cruise control.
I am trying to avoid having to go to the dealership 50 miles away. Is there a way to get the code for my particular wheel?
It is a 2013 C4S and the wheel is identical to the one in this picture:
https://imgur.com/a/qWuarhw
Old Jun 13, 2020 | 01:36 PM
Lotusnfg's Avatar
Lotusnfg
Default Coding
You need PIWIS, depending on your car. If it is a 2016 or older I can do it for you, case of beer.
Old Aug 23, 2021 | 08:56 PM
dangphoto's Avatar
dangphoto
2nd Gear
Sorry for digging up an old thread. Would love for your help, although I am in CA. Bought PIWIS and have been messing around with it but I can't seem to figure out how to enable the PDK neutral on my new SD wheel. Did you just add it (checkmark the install) in under "Maintenance of Vehicle Data"? Thanks for your help
Old Jan 24, 2023 | 03:07 PM
Si widd's Avatar
Si widd
Default Interested if you can help me
Hi mate, i hope you are well.
I'm interested in getting a code for my 981, I've just replaced the steering wheel and Porsche have refused to supply me with a code as I didn't get the wheel from them.
Can you help or point me in the right direction please. Happy to pay.
Simon.
