Overrev report concern?
Old May 28, 2020 | 12:43 PM
Schn3ll's Avatar
Schn3ll
Default Overrev report concern?
Hi All, looking at a used 2019 991.2 with 5k miles.
DME report came back with the following:
Range 1: 1982 / 294
Range 2: 571 / 291
Range 3: 1 / 90
Range 4-6 - nothing
Should I be concerned?
Thank you in advance!
Old May 28, 2020 | 03:31 PM
jeffbrig's Avatar
jeffbrig
The 1st number is the # of revolutions in a particular rpm range. The second number is operating hours on the engine when that range was last encountered. Range 1 can be hit under acceleration by bumping off the rev limiter. Not an issue. Range 2 or higher generally indicates an overly aggressive downshift. Range 2 is still fairly mild and unlikely to cause any issues. A single revolution at Range 3 around 200 operating hours ago doesn't seem like a huge concern to me. Range 4 would raise eyebrows, and 5/6 just scream "run away".
Old May 28, 2020 | 03:33 PM
Schn3ll's Avatar
Schn3ll
That's all I needed to hear, thanks!
Old May 28, 2020 | 03:35 PM
fnckr's Avatar
fnckr
No concern. There are several videos and posts that go into detail. One revolution is usually an anomaly. The others in range 1 and 2 just show a spritely driven car that approached redline. No issues or long-term concerns with this one, based on that report.
Old May 28, 2020 | 04:54 PM
NiteJav's Avatar
NiteJav
That range 3 could have been a near money shift if the computer was blipping the throttle, it realized it was not in a good place (computer bailed out) and the driver never let out the clutch to complete the money shift. Should be fine.
Old May 29, 2020 | 07:42 AM
Quadcammer's Avatar
Quadcammer
The numbers are not revolutions, but ignitions, so 3 per revolution
Old May 29, 2020 | 08:04 AM
LexVan's Avatar
LexVan
While that report is not concerning, it's also very incomplete. Ideally, I'd also like to know:
total mileage
total operating hours
counter start cycles
