911 Oil Consumption?
Received 5,413 Likes
One thing to keep in mind, with low mileage, low use cars, with short trips....the oil is accumulating moisture, so as oil is being consumed (200-400 mls) the void is being backfilled by water, and net-net the oil level stays the same.
What if we are bringing the car up to operating temp ~193 degree oil? I was under the impression moisture will burn off.
note, water purification process takes water to steam and then cool it back to water.
Need to get the all the oil to circulate through the turbos at operating temperatures. The heat it encounters there will burn off any water in the oil.
