Bored. Want to do a Brake Job
Hi gang.
I'm due for a brake job on my 991 and figured that instead of sitting around watching automotive channels on YouTube and mixing up another cocktail, it might be more fruitful to save $800 plus in labor and $500 in parts and fix my own car.
I've done brakes on other cars of course, but not recently or on a Porsche.
Anything interesting that you guys have run into when doing this that I should be prepared for?
TIA
TIA
Since Porsche recommend you replace the bolts, I would buy the stud kit from a Tarett and the brake line bracket studs. these little studs for the brackets are life savers but only needed for front. Lol
don’t need to loosen anything on rear, only disconnect the ABS sensor wire.
https://www.tarett.com/items/986-987...csk-detail.htm
https://www.tarett.com/items/986-987...bsk-detail.htm
Need4S (05-13-2020)
I've seen conflicting information on the sensors: For a '17 base C2, are there two sensors on the front, or just one?
The Pelican parts web site seems to indicate that two sensors "per car" are required? That's "two front sensors" per car, right?
https://www.pelicanparts.com/More_In...0017&DID=11349
I know some folks reuse these, but it's usually my infernal luck to bust them when replacing on my previous brake jobs (bimmers, mostly) so I plan to have what I need on hand.
Rich_Jenkins (05-05-2020)
Nice tips. I was planning on buying new sensors and probably will since that's the cheapest part. Since I am doing it before any contact with the rotors I might not have to.though. I will check Pelican. I was thinking FCP Euro as well as a good supplier of this stuff.
I like the tip about painting rotor hats. That's an easy little upgrade!
