How to lubricate the O-ring
I got the combo (filter, housing and o-ring) from my dealer. https://www.sunsetporscheparts.com/o...ing-0pb115403a
The o-ring is already "installed" on the filter housing. Do I need to remove the o-ring in order to grease it fully? Or can I apply the grease to the o-ring as it sits on the filter housing.
The part of the o ring that needs to be greased is the outside as this needs to slide along the filter housing as it is screwed in.
It is easy to remove the o ring with a small flat head screwdriver if you find the cutouts that should exist in one part on the slot
holding the o ring. These cutouts allow you to get under the oring without damaging it. It you remove it you can grease both sides of the ring.
Yes you were supposed to replace it. But there's a very low chance of a leak. They always seem to be in very good condition when I replace them. You will know there's a problem if it leaks. Otherwise just replace next time. By the way, you are supposed to lube it with oil, not grease.
Its okay, not worry. and I have reused them also..... only with long age would they get cracked which is why you would replace them
