911 T rear window confused
Hi, I am my new to me 911 T loving a lot!
I noticed someting odd.
on my spec-card is mentioned : Privacy Glass rear window.
and yes, it is a little tinted Just right imho. But After a detailed look I found out that there is alro rearwindow heating present and working. I love that, but now I don,t think I have te gulerra glass. I am a bit confused. Somone who used the confusionator when ordering who can clarefy this to me? Thx all!
other question; on a wet surface the back really is a hand full to control. I really love that but the missis will be scared. I am running the Michelin 4s sport tyres with the low ambient temperatures in this season. I hate wintertyres. Anyone with 4s tyres experiencing the same issues in wet conditions with psm activated?
Running Michelin Pilot Sport 4S tires in winter conditions is just stupid... that's why your car is hard to control.
![manual](https://rennlist.com/forums/graemlins/rtfm.gif)
The following 2 users liked this post by Crester:
63mercedes (02-25-2020),
The Ox (02-24-2020)
And what pressure are you running in your rears? If Max Load (45), then that is also a contributor. Max Load on any tire when you aren't fully bogged down with stuff allows some slippage, even dry, in my experience. Not to mention a harsher ride.
You were spec'd with regular glass most likely. Easy to check, push your rear sides, and then your rear. If same, no. If different, yes. Good Luck!
SS
SS
GG does not come with heating elements/defroster...one of the tricks when spec'ing the T was not to order the privacy glass on the config as they would replace with normal glass. I heard about this on one of the 911T threads. But if you live someplace cold you may want such a feature. Like for instance, I live in a warm, sunny place and wanted a sunroof. To each their own.
S S (02-25-2020)
