front spoiler damage repair
Anyone have a suggestion about how best to repair damage to the bottom of the front spoiler on my 991.2 Carrera GTS? Clearly I drove over something that gouged it.
Thinking about sanding it smooth - or just leave it alone??
Easy repair with some body filler and sanding. Paint will be the issue if you’re trying to match.
Sand it down, buy some oem spray paint, light wet sand, polish, wax.
Sounds like nice diy job. Being so low on the car, if paint is not perfect match, or the diy is not perfect, it will not be an issue as it will not be easily noticed.
I would leave it alone, and then replace when it gets a bit more, ahem, aged.
Driveby (12-28-2019)
I also have a GTS that had a similar issue when i bought the car. I wanted it perfect, so I just bought a replacement on suncoast and had a local shop paint it. Total cost was around 400. It took a week to scrape it up again. So now I just live with it. I would like to find a plastic non painted replacement like the GT3 has.
