Porsche 991.1 Bose Amp Location
Hey guys,
Have been having an issue with my PCM where everything works but I get no sound. when I switch source it doesnt switch the source.
I have a PCM 3.1 with the latest V3.76 version. I tried hard resting, even bought an upgrade version CD and still had no luck.
Not sure if it is a PCM issue or a speaker issue but my next step is to try and check if I see anything in the amp (hear it has its own fuse).
Does anyone know where the bose amp is located on a 2013 Porsche 911 991.1?
The amp does have it's own fuse.
Looks like Row C #10 on the passenger side fuse panel. If there is no communication with the BOSE amp, you can loose the ability to change input sources.
http://www.porscheownersmanuals.com/...ual/6/243/page
