Passenger Window Switch Not Working
Hi everyone.
Bought my car unseen and noticed the passenger window switch isn't working, doesn't even light up at night.
The window works normally from the switch on the driver's panel.
Does this usually mean a new switch is required (seen them cheap on Amazon) or is it something as simple as a fuse.
Many thanks.
Many thanks.
I had the dealer change it out. CPO fix. Door panel needs to be removed.
Door panels are easy to remove. I actually had to remove the passenger side because a rubber wedge had fallen out of the holder after the dealer replaced the switch.
Second that. 991 door panels are very easy to remove.
