Alarm Setting
Question on my 991.2. When you exit and lock the car with keyless and then open the trunk, the car is unlocked and the alarm disabled. You then have to go back to the door and lock the car again. Is there a setting or procedure to lock the car, open the trunk, and then have the car lock itself without having to go back to the door? And no, I don't want to use the key fob.
Not that I know of. Once you open a door, frunk, engine cover, you have to re-lock the car. If you unlocked car and did not open anything the car would lock itself and re-arm after 20 seconds or so.
sr5959 (11-26-2019)
