Excessive Wind Noise From Window Seals
Old Nov 20, 2019 | 04:47 PM
Msgm1's Avatar
Msgm1
Default Excessive Wind Noise From Window Seals
I think i’m Having excessive wind noise from my windows.
I have a 2013 Carrera S Cab, with 75k on it.
Anyone else had these issues and if so fixed it?
Old Nov 20, 2019 | 06:03 PM
LexVan's Avatar
LexVan
Clean your door seals.
Condition door seals with Aerospace 303 and/or Gumi Pledge (spelling?).
Old Nov 20, 2019 | 06:18 PM
Bob Z.'s Avatar
Bob Z.
Veteran: Navy
Silicon in the spray can (water based) is also good for rubber window seals; however, have you noticed any indentation, cuts, etc.? One or more may need to be replaced if so.
Old Nov 20, 2019 | 07:08 PM
NJBThor's Avatar
NJBThor
Are the windows all the way up? I get whistling sometimes after I start the car up, and the windows don't fully return to the door channels.
Old Nov 20, 2019 | 07:11 PM
LexVan's Avatar
LexVan
That's not normal.
Old Nov 20, 2019 | 07:30 PM
NJBThor's Avatar
NJBThor
Originally Posted by LexVan
That's not normal.
Its intermittent, but I'm scared to see what the dealer will charge for the repair (its a 2013 and the CPO expired in May)
Old Nov 20, 2019 | 07:31 PM
Msgm1's Avatar
Msgm1
Yes the windows are all the way up
Old Nov 20, 2019 | 08:29 PM
gravord's Avatar
gravord
It's interesting to see that someone else is having this problem. After starting up, my passenger window remains slightly open. It was intermittent, but now it happens every time I start up.
Old Nov 20, 2019 | 09:07 PM
Time4Porsche's Avatar
Time4Porsche
Do you have a clear film on your side mirrors? If so that could create some noise you mention.
Old Nov 20, 2019 | 09:28 PM
Al.Fresco's Avatar
Al.Fresco
​​​​​​​Try the recommendation in post 8 here.... https://rennlist.com/forums/991/9178...dow-issue.html
Old Nov 20, 2019 | 11:48 PM
NJBThor's Avatar
NJBThor
Thanks, I will
