I have an old Sears Diehard Battery Charger/Maintainer that produces 1.5 amps that I've been using on Porsches and various motorcycles for ten years or so.
However, it's not the optimum charger for AGM batteries, as it only produces about 13.5 volts, which I believe is slightly less than the optimum voltage required to maintain an AGM battery. But so far I have not experienced an ill effects from using this old charger/maintainer.
Does anyone know if the 12v charging adaptor for a trickle charger has to be like the one illustrated in the manual as I can’t find one like that. The manual says that failing to use one as illustrated might cause damage to the electrical system. Just looking at pictures of the Porsche one and that adapter doesn’t look like it complies.
The CTek 3300 is the Porsche Branded one, just without the Porsche Branding. Just get this adapter and you would have the same thing.
