KW HAS and DCS on SPASM GTS Coupe
Curious what the benefits of a DSC module are on a SPASM equipped GTS with KW HAS kit lowered about 3/4". Read many threads about the DSC module but most of them relate to PASM equipped cars. I'm just not sure if or how different it would be on SPASM. Anyone?
Received 3,400 Likes
There are a couple in the Marketplace for sale, which may be a good way to give it try, and if you are not impressed simply put it back out there and sell it someone else.
Just receive my module and will install hopefully today. After few rides will share my opinion. To my understanding the module improves ride quality and provides the option for full custom setup for PASM or SPASM cars.
Many GTS also GT owners have install the module with quite positive feedback.
PS. Excellent service from TOM at DSC. Very professional and ship the module in EU. Thank you TOM.
Tom@TPC Racing (10-26-2019)
Basic Sponsor
Thank You!
Tom
Dedicated Performance. Daily Comfort.
sales@dscsport.com | (410) 799-7798
Facebook | Instagram | Twitter
Sign up for our Newsletter
DSC Sport (10-26-2019)
Basic Sponsor
Thanks Bob Z for chimming in!
Eysa, what Bob Z posted is correct. And in your particular car, since you have installed KW HAS featuring stiffer springs, not only will you beneift from all the DSC goodness that users rave about, your expereince should be a level above since the stiffer springs and lowered ride height really respond well to extra damping force prodcued by DSC.
Does that mean it won't be as bouncy? I'm not saying my car is bouncy as I don't have the KW kit installed just yet(should be done next week) but the bounciness i've experienced on previous lowered cars is what made me more hesitant to lower my GTS. I ended up with the KW kit because from what i've read its the closest to the factory springs rates which should ride best but if the DSC make that much difference i think ts a no brainer.
Basic Sponsor
Basic Sponsor
V2 is the older model that was last made in 2017. Since then we have only made V3. V3 has more powerful processors to achive much faster Velocity function. Velocity function is an exclusive DSC feature that uses the factory ride height sensor data to adjust high speed, medium speed, and low speed compression and rebound damping force for individual damper as you are driving.
On the topic of PASM vs SPASM what are the hardware differences? I’m aware that SPASM sits lower which I presume is a shorter spring? That may be a wrong assumption. What about the shock, is it the same?
Honestly speaking it seems DSCV3 is a magic box.
I have completed the installation in 3 mins in my 991.2 C2 GTS.
After drove the car for around 100 kms in road conditions i can say that the sport PASM feels much softer and very smooth. In the past i used to drive my car always in normal mode as the car was quite bumpy especially with my kids inside the car.
Now the car in sport mode is same level even softer than normal mode but when i press the acceleration and push the car automatically the suspension becomes stiff.
I need more time to drive the car especially in mountain roads and try to understand the behavior of DSC controller.
It is a pricey mod but i strongly believe it seriously improved car ride quality and even track time.
