Former RS owner's first 991.2 GTS Track Day
Very Detailed. It's crazy to think that with a proper/track focused brake and tire these can keep up if not outperform a GT3 variant. I wonder if you tune/add some downpipes, in addition to brakes and tires, to bump that TQ up so its happy all the way to redline, how much time youd shave off. Great stuff!
dsddcd: I'm in a similar boat. GTS is my DD and I won't go down the slippery slope of adding performance on track at the expense of street civility. I honestly believe that with brakes, brake cooling, tires and possibly a 3rd radiator, the car would be capable of pretty incredible things. I still have to balance that and the cost with maybe tracking a few times a year and ROI. I spend more time on my other main hobby so 4th/5th priority for track performance is about where I sit
Please post up your results after you get everything in. I suspect the car will be fantastic.
Go for it! Having owned a decent amount of Pcars, I think the GTS is a real sweet spot for a street focused car that can do occasional track days. The torque around town is awesome.
Chris
same boat as you but I came from a 996GT3 and decided on a T. I also came to realize that OEM tires and brake pads are not up to track use.
The M4S will not hold up on the track, the cup 2 will do better on the track, However, after 1-2 track days, neither tires will not be suitable for street driving.
Therefore, The best option is to have two sets and swap tires and pads prior to track day and keep the 4S and OEM pads in good condition for DD.
I changed the caliper bolts to stud kit and Spiegler 6 piece set stainless brake lines and with brake line stud kit. This does not affect DD drive ability but makes pad change easier. Also get the DSC box for you suspension, improves DD dynamics and track use with OEM coil overs.
I ended up liking 35f/36r hot as a compromise.
I'm not one for perma spoiler but after a session, it lets the engine compartment "breathe" a little and dissipate heat.
Can you please provide your feed back on the tractive dampers, I have them on my wish list. I’m especially interested to hear about the ride quality during street use and if it can match the stock quality. I thinking about a set for my .2 GTS. Thanks
I did drive a 991.2 Carrera S with stock dampers, springs and full spherical bushing set for 11 Hours straight today and was very impressed how civil that car was so I am hoping the Tractive will be as good or better.
OP: Agreed.
Similar experience when I tracked my 991.2 C2S. The strong point (esp. on technical track) is the motor, weakest point is street tires. But IMHO Cup2 is only a marginal improvement over 4S - still get greasy quick and require a lot of air pressure tinkering but do generate more grip obviously.
Great write up. I have gone from Cup2's to TrofeoR to now AR-1 semi slicks, and shortly full slicks on track wheels.
The TrofeoR is the best all round tyre if you track. The Cup2 is a considerable improvement, however it does not have enough stiffness in the sidewall for heavy tracking. I split one. The TrofeoR was much better.
The AR-1's are great on the track, but suck on the street from dreadful road noise. Sounds like a 4 x 4 hum. So I need track wheels next.
I have Tractive suspension. It is epic. It delivers as promised. Even with my serious spring rates, it is still street compliant at the push of a button. very pleased with tractive.
I agree the GTS needs Aero.
So........ I did this.
Just waiting on the PWR centre radiator. I will upgrade the outside two later as well to have all 3 PWR.
Brakes I run 380mm Brembo GTS. The stock brakes just did not cut it for serious tracking. (Even with pagids and steel lines and Castrol SRF.) If you track hard, go straight for BBK upgrade.
P.S. Pagid RSL 29 suck on the street. Squeal like a city bus. Endless ME20 are awesome all rounder front pad.. Epic on the track and street and soft squeal after track transfer wears off, but it is less than what stock brakes squealed.
I run endless Mx72+ in rear and they are silent and not wearing at rear at all....FINALLY!!!
