Loving Apple CarPlay but... irritated as well
Anyone else loving Apple CarPlay BUT forgetting their freakin' phone in the car. Argggh!
Options? But a second phone for the Porsche and leave it in there?
Ideas, please!
Ideas, please!
Received 2,279 Likes
Just remember your phone. It's not hard. First world problems.
How does your car drive BTW? lol
The following 2 users liked this post by subshooter:
hbear (08-22-2019),
k.alexander (11-27-2019)
Better problem than having an Android
0luke1 (08-23-2019)
I've found that if I put it in the cubby/on the antenna pad, I will pretty much always forget it. If I leave it on the seat, when I can, I'll remember it. Out of sight, out of mind thing...
SS
SS
get a phone holder so the phones is always visible. i've never left my phone in my car lol
Omega4 (08-23-2019)
Absolutely, buy a T-Design9 Monaco Wireless Charger and only use the magnetic function to mount the phone.
Run the cable to the phone magnetically mounted on the above and you will have both CarPlay + Magnetic Mounting right in front of you making sure you never forget to unplug your phone when you leave.
For OP use, the T-Design9 Monaco Wireless Charger would not be powered, which means it will not be plugged in to anything. Just using the super heavy duty magnetic mounting capabilities + plugging into Lightning Port to activate CarPlay along with wired charging instead. - My buddy is doing this in his .2 GTS.
For those who don't want to use CarPlay, then the T-Design9 Monaco Wireless Charger will either be plugged into the USB port in the glovebox, or use the 12V power source at the passenger footwell. - I'm doing this in my .1 RS.
Both these setups work seamlessly with no problems whatsoever.
Has anyone figured out a fix for this ?
I tried the second "car dedicated" phone option so that I can keep CarPlay active (mostly for Waze, but also the V-1 app, Porsche TrackPrecission/Car Connect apps) but ran into one huge issue - PCM shuts off the bluetooth connectivity when CarPlay is active. So - any calls on your primary phone will no longer be handsfree while your car-phone is connected to CarPlay. Of course you could forward your primary to the car phone, but that sort of defeats the purpose of managing all of this effortlessly.
For most of my drives, including my daily commute, I prefer to connect via Bluetooth. The beauty of using BT is your phone can stay in your pocket, it will automatically connect to whatever audio you were last listening to (spotify for instance, which shows the album art). You can also take a phone call without touching the phone. So when I get out of the car at work, phone is still in my shirt pocket. I only use CarPlay for longer drives.
good2go (08-25-2019)
I have a magnetic phone mount and use Amazon Unlimited music. So it's Bluetooth, and all my commands are super easy over Alexa. Really pleased with this setup.
If you aren't using the wireless charging and just using the magnet, you can save money with this version. It also shows how it mounts.
