991 Brake Pads and Rotor replace DIY
Do you mean as in when you use the pad spreader to push the pads in? Yeah, so I just keep an eye on the MC and make sure the fluid doesn't come up through the vent and make a mess. I put some rags around the mouth just in case. But to be honest I don't recall the fluid rising much at all when I did mine, but I only had to spread the pads enough from about 7mm wear. (my rotors were lipped which was the primary reason I did pads and rotors).
Former Vendor
From: Reno/McCarran, NV - Bay Area, CA - NW Burbs of Chicago, IL
Here are the direct links to both if you are interested:
Endless MX72 EIP240 Brake Pads Porsche 911 Carrera S/GTS/Turbo/GT3 (991) Front
Endless MX72 EIP215 Brake Pads Porsche 911 S/GTS (991) Rear
Endless Premium EIP240 Brake Pads Porsche 911 Carrera S/GTS/Turbo/GT3 (991) Front
Endless Premium EIP215 Brake Pads Porsche 911 S/GTS (991) Rear
-Matt M.
The following 4 users liked this post by SpeedFreaksUSA:
acwild70 (06-16-2021),
AdamSanta85 (06-17-2021),
midwstCostofLivg (04-24-2023),
thesaintusa (09-10-2022)
Consider brake fluid flush while you are doing brake pad/rotor replacement. You are already there anyway so minimal extra labor. Some use this opportunity to also switch to SS brake hoses.
The following 2 users liked this post by Fullyield:
acwild70 (06-17-2021),
Rich_Jenkins (06-17-2021)
There are two very popular options from Endless - MX72 and Premium compound. MX72 is an excellent option if you want to increase the performance over the stock pads while reducing the dust. However,
if the ultimate goal is to reduce dust output as much as possible without sacrificing too much on initial bite, overall friction and all the other attributes Porsche intended the brakes to have then Endless Premium is a top contender.
-Matt M.
-Matt M.
The following 2 users liked this post by AdamSanta85:
SpeedFreaksUSA (06-17-2021)
This thread with the links to step by step guides and the youtube video was very helpful as I went through rotor replacements at all four corners.
The biggest time suck with the whole job was dealing with thestupid center lock wheels, but they aren’t too bad now that I’m used to them.
I ran into some issues as the wrong pads showed up and I didn’t notice until I went to install them. There’s enough life on the old pads for street driving, but no way could they make it through another track day.
I decided to stick with Ferrodo DS2500 pads as they’ve worked well on the street with only a bit of noise and they’ve held up well on track.
For rotors, after 11.5k miles and ~14 track days, the OEMs were thoroughly cooked in the front - considerably cracked and small chunks breaking loose from the outer edge of the rim of the discs. The rear rotors were in much better condition, but I made the choice to swap out all four with Essex’s APracing 2 piece rotors. Essex very helpfully includes longer caliper bolts and spacers for the rear to accommodate the new 350mm rear size (up from I think 330mm OEM).
I also added Tarret’s caliper and brake line bracket studs to the front while I was in there. I probably won’t be swapping pads enough to truly merit the stud kits, but it seemed better than Porsche’s (allegedly) single use caliper bolts.
The Precision Instruments torque wrench and breaker bar kit and Jack Point stands were a huge help.
If the correct pads arrive in time, the next track day is July 12th at LRP with CVR, so I’m eager to see if I notice any difference in brake performance.
Thanks again to all who contributed to this thread and also to Essex whose customer service and products both make for a winning combination.
(and, no… I am not obsessive about the cleanliness of my car. I hope no one is triggered!) 🤣
Rich_Jenkins (06-19-2021)
Just replaced my factory pads (7,000 miles on them) with Hawk Ceramics this weekend. I have black wheels and I had to stop the semi-metallic dust. The factory pads are for sale, btw ($100 + shipping) if anyone wants them. I also installed the Tarrett Engineering caliper studs. Some say the rears are more difficult, but I found them to be much faster as only the pad wear sensor and the caliper have to be removed.
Also, here's a tip to make it easier on you. Disconnect the wear sensor, remove the rear caliper and THEN remove the pad wear sensors from the brake pads. It is much easier to get to them after the caliper has been removed. I highly recommend the Tarrett Engineering studs. Re-installing the calipers was much easier than when using the OE bolts.
I also installed ECS spacers 5mm front and 3mm rear while I was at it.
acwild70 (06-21-2021)
thanks
Jay
I just did the rear rotors and pads on a 2013 c2. The information on this site and YouTube have been priceless. A couple of things to share:
(1) I found the easiest way to remove the sensor cable is to use a small Allen wrench. Hook the small end in the clip and pull with the other end. It makes unclipping the sensor a breeze. See picture showing what I did. I had unclipped the sensor at this point.
(2) I was torn on how to raise the car from the back as I was reading all sorts of opinions. I ended up raising the car from the back via the middle of the rear cross member and then used esco jack stands in the designated rear jack points. Although not a fan of the height cause putting the wheels on was a pain. If I had to redo I would get shorter jack stands. Any recommendations?
(3) Rotor screw was warped. Invested in a impact screwdriver which was worth it. Did not want to go through the hassle of drilling.
Happy to answer any questions.
The following 2 users liked this post by Ark20:
fsmich (10-04-2021),
Rich_Jenkins (10-04-2021)
So many people on RL have recommended the JackPoint stands that I went ahead and purchased a pair too. I’m able to jack up the rear of the car in conjunction with these and simultaneously place normal jack stands up front. While they seem to always be out of stock, I contacted him and got on a wait list and got them reasonably/acceptably quickly.
https//shop.jackpointjackstands.com/JackPoint-Jack-Stand-Pair-Low-Profile-Pad-Matte-Finish-JSLPMF.htm
Ark20 (10-04-2021)
Ark 20- thank you for the Allen wrench tip and photo. I went ahead and bought a Quick Jack ($1,000) which was best $ I have spent since it works on 911, Tacoma, and wife and children’s vehicles too. Garage ceiling too low for a 2 post or 4 post lift.
Ark20 (10-04-2021)
Great tip on the sensor connector/Allen wrench. Getting that connector unseated was a significant pain in the rear when I did my front pads and rotors in Feb. FWIW I used my cordless 1/2" impact wheel gun on the brake disk rotor screw; made short work of getting them out.
Question: for the rears especially, did you have to do anything extra to account for the parking brake, in terms of retracting the old pads, or resetting the parking brake after the brake service?
Another tidbit is that my old sensors only had one indicator while the new one had 2. I attached the sensor which is on the inside pad first by pulling it ,as much as possible, in the caliper from the back and attaching to brake pad before setting the brake pad in the caliper. I then set the outside brake pad in the caliper and plugged in the other sensor. Pushed it carefully with a small screw driver till it set. Once both sensors were clipped then I used the small screw driver to place the wires in the place holder at the back of the caliper.
Rich_Jenkins (10-05-2021)
