Jack pads
Old 08-10-2019, 04:54 PM
991.1GTS
991.1GTS's Avatar
Default Jack pads
Greetings all - anyone have a convenient source for jack pads for our cars?
Old 08-10-2019, 05:34 PM
LexVan
LexVan's Avatar
Received 5,407 Likes on 2,514 Posts
You want one with a centering bolt, too. I have Rennline's. There are several options out there. Just don't use an old hockey puck.
Old 08-10-2019, 06:18 PM
Bxstr
Bxstr's Avatar
Received 3,099 Likes on 2,119 Posts
I think a guy on here makes them as well. Pretty sure it is smokingts.
Old 08-10-2019, 06:21 PM
BlueNorther
BlueNorther's Avatar
You can have mine. Centering bolt is a PIA. I've gone back to regulation hockey puck, works great. I don't need belts and suspenders.
good2go (08-10-2019)
Old 08-10-2019, 06:36 PM
good2go
good2go's Avatar
I grabbed a hockey puck from the basement. Works great.
Old 08-10-2019, 07:07 PM
Jack F
Jack F's Avatar
I have Quick Jacks and they come with rubber blocks that I feel are a bit too soft. I use the Delrin jack pads made by a rennlister and they work great. Just today I bought 12 hockey pucks for $20 and plan on using them as the in between the Quick Jack and the delrin 911 pads.
I wonder how much compressive force a hockey puck can withstand stand. Wish my 20T hydraulic press had a pressure gauge.
SDaddy (03-15-2020)
Old 08-10-2019, 07:11 PM
BOPE
BOPE's Avatar
I only use "Porsche-Certified" jack pads! You can't get any more convenient than making them in your garage.
The following 2 users liked this post by BOPE:
Honda (08-11-2019), PhillyNate (08-11-2019)
Old 08-10-2019, 07:15 PM
Jack F
Jack F's Avatar
Wood! Who would have thunk? Do you replace them every now and then?
Old 08-10-2019, 07:32 PM
BOPE
BOPE's Avatar
This pad has been used on three (3) Porsches and is still solid. I have one for each jacking position.
The centering dowel is made from a 1-inch diameter pine dowel that has been glued to a 1/2-inch thick piece of plywood that has been drilled to accept the dowel. The plywood with dowel are then glued to 2-inch X 2-1/2-inch X 3/4-inch thick piece of poplar.
Jason
Honda (08-11-2019)
Old 08-10-2019, 08:00 PM
Bob Z.
Bob Z.'s Avatar
Received 3,447 Likes on 2,357 Posts
I have a set of these and they work great, and they are made by a Rennlister: https://rennlist.com/forums/market/1134984
The following 3 users liked this post by Bob Z.:
991.1GTS (08-13-2019), cryptical1200 (08-11-2019), Rich_Jenkins (08-11-2019)
Old 08-10-2019, 08:07 PM
BlueNorther
This pad has been used on three (3) Porsches and are still solid. I have one for each jacking position.
Jason
The paint on the top is a nice touch! I'd go for guards red
Old 08-10-2019, 08:13 PM
BOPE
BOPE's Avatar
Ha, I'm a Guards Red fan myself.
The orange is a color code denoting the size of the dowel, in this case 1-inch diameter.
Jason
BlueNorther (08-10-2019)
Old 08-10-2019, 11:36 PM
991.1GTS
991.1GTS's Avatar
Thanks everyone, I ordered the Rennlines.
Cheers
Old 08-11-2019, 01:19 AM
Valvefloat991
Valvefloat991's Avatar
Love it. Did you consider making the bases round to fit the jack cradle better?
Old 08-11-2019, 09:59 AM
BOPE
BOPE's Avatar
I chose the rectangular shape primarily because it was easy to construct and the interface point on the car is rectangular. Also, the rectangular shape provides a bit more bearing area when the pads are used with my jack stands.
But you've given me an idea. I just may "clip" the corners to provide and easier interface with jack cradle.
Jason
Quick Reply: Jack pads
