Radiator fans not working
Both radiator fans not working on my 2013 991 Carrera S. Want to check the relay's first but can't find the fan relay location. Anyone know where it's located?
Checked under the drivers fool well and behind the fuse cover. Nothing...
None. No codes pulled up. It sure seems like the relays are bad or possibly the ballast/ fan motor. Surprised there aren't more posts on this topic here for the 991 platform. It's common in the 996/997 and both of those models have the relay panel right next to and above the fuse panel in the driver's footwell.
View this video and focus on (5:50) run time to test the fans for operation.
https://youtu.be/XsPeDvJXEUs
I believe it's in the driver's footwell. They are above and towards the firewall relative to the footwell fuse panel. Relays K4 and K5. From my research it's NOT EASY to get to. You basically have to disassemble half the driver's side footwell & dash.
Parts research:
https://www.sunsetporscheparts.com/a...and-relay-scat
https://nemigaparts.com/cat_spares/p...91t/42/902000/
Start with post #17 in this thread to see the madness to get to the relay panel.
https://www.6speedonline.com/forums/...ay-fuse-2.html
Parts research:
Parts research:
Parts research:
HUGE help! Thanks so much for posting this.
Class5Kayaker (07-25-2019)
Parts research:
Parts research:
Hi, would you know which relay it the one that controls radiators? I looked at the electric diagram, and it seems that there is one relay for each radiator. My guess, given the picture I attach is that the 2 relays in charge of fans are the ones marked as "644"?
