Foam tape Insulation/soundproof
Hi, anybody have any recommendations for insulation foam tape that helps quiet rattles. I have looked back through previous posts, but can't find anything Looking for the best product out there through Amazon or anyone else. Thanks in advance!
Interior rattles? Use pieces of leather instead.
You can use the foam window weatherstripping readily available from home depot or lowes. It is adhesive backed and comes in all different thickness and firmness. Its good for padding plastic on plastic or metal rattle areas.
Received 3,455 Likes
I am using some of that right now, black foam with adhesive on both sides from Lowes, who gives a military discount all of the time so I never go to the orange/black place but they should carry it as well. Another option is using microfiber polishing pads if you have a larger area that you want to cushion.
