Shock towers squeaking ??!
Around the shock absorber center nut (The nut with the cable going into it). You should be able to see some of the rubber mount around that nut. I used Formula 303 protectant because I felt that the liquid would penetrate better than grease and won't damage the rubber, but others have had good luck with lithium grease. My one time spray has lasted around 4 years now!
Received 5,413 Likes
