Question for 991.2 owners that have installed the Cobb tune
Also need to add high flow filter, car needs more air as well. Those poor little things are sucking like crazy and are getting all winded.
Question, from what I have read, with stage 2 type or custom tunes, isn’t it recommended to go cat less?
plot of your run ( datalog 7 )shows opening of throttle blade and wastegate occurs at 6000 rpm.
Throttle blade changes angle even if you have your foot planted based on ECU.
Calculated engine torque was running at ECU limit ( might be why throttle blade opened up).
RPM is blue ( divided by 100), yellow is net boost in psi, grey is wastegate, brown is actual throttle blade angle.
2. Thats the craziest plot ive ever seen
3. This is gonna be interesting
4. OP. I hope its just the software
Stock map shows same effect on boost, throttle blade, with your setup at 6000 rpm
red line if ECU max torque allowed, green calc torque
throttle blade opens if calc torque rises above max torque
note with tune you were getting boost of 25psi, torque of 540 ft-lb
stock map boost of 16 psi, torque more like 420
I don't feel the boost drop at stage 0, but maybe because the boost wasn't as crazy before 6000rpm thats why it feels smooth. So you guys think is the fuel problem right?
edit: it's not unheard of for the premium tank at the station to have been filled with regular (accidentally or not...). I bet you just got a tank of low octane fuel.
What about intercoolers, did you upgrade? if not, this is your next step along with airfilter, plenum and maybe consider removing cats.
When tuning turbo charged engines, need to increase air mass and improve airflow. First and easy gains are;
1. Air filter
2. Intercoolers
3. Cats.
For stage 2 type tune and incremental change in airflow;
1. Plenum (and intercooler if not already completed)
2. Headers/down pipes
3. remove cats, replace muffler
1. Air filter
2. Intercoolers
3. Cats.
For what it's worth, my car was used to develop the stage 2 map. I have akra cats and exhaust and no other mods, so that's what the OTS stage 2 map was developed with/for. With my setup, I have none of these issues. It pulls strong all the way, and there is no clunkiness or other drivability issues.
Just wanted to clarify for the people saying you need this or that for the Cobb stage 2 map. You only need high flow cats and nothing else.
