Retrofitting PCM4 in a 991.1
#32
#35
are there any interresting infos stored in the emmc , i saw there are the maps stored, also the mnand has partitions /app but i not really know for what the partiotions are, i am trying to read it in a vw unit the pcb layout
is different.
have you maybe find some Jtag pins for the MMX board or the RCC to read write the NOR flash,
is different.
#36
is different.
is different.
You could dump it over JTAG but I wound up not doing that since it was easier to desolder the NOR and dump it with a flash reader. If you can force the system into emergency mode, the password is “harman_f” and you can dump the NOR to the sd card through there
subaru335i (04-26-2024)
#37
This project is slowly nearing completion, I am now just waiting for a CAN gateway from a 991.2 and need to remove the amplifier + rewire the sound system.
Some more coding findings
Byte 1 = 07 (Porsche)
Byte 2 = 46 (911), 44 (Cayman/Macan)
Byte 3 = 44 (GT3): Bit 1 = Car Generation (0-9), Bit 2 = Car Variant (0-9). Change these two bits to match your 911's model.
Byte 20 = 02 (External Amp Bose - MOST), 01 (Internal Amp), ?? Burmeister
Note that in addition to the PCM4 head unit you will need:
Amplifier (ASK / Bose / Burmeister have changed in 991.2 and may not work properly w/ PCM4)
CAN Gateway (95B907530G)
USB:
- Multiple USB Ports: USB Hub (5G0-035-953-C) + USB Cable / Port (9A7-642-953-00 center console, 9A7-642-222-00 aux + usb) + USB Hub Mount (9P1-035-925-A)
- Or, for single port: USB+Aux Cable (5Q0 035 726E) + Port (5G0-035-222-E), you can reuse glove box usb/aux/12v trim.
Dashboard PCM slot requires cutting to accommodate PCM4 cooling intake fan
PCM4 can communicate with the 991.1 CAN gateway, but for some reason the clock is set at 12AM and the instrument cluster can not see any information from PCM. I think the gateway can be recoded to work correctly with PCM4, however the gateway is locked with a security access code, which I can not find, if somebody knows it please let me know.
If you do not have an amplifier (under passenger seat), you can wire your speakers to PCM4. Otherwise, you may need to replace or bypass your amplifier. My car has an ASK amplifier (SPP) and I am unable to code it properly to the PCM4 since SPP now uses the internal PCM amplifier; feeding the PCM4 speaker outputs to the ASK amplifier results in super loud audio since PCM4 either outputs amplified audio or pre-amplified audio over MOST. Options for SPP cars are either upgrade the audio to Bose, or remove the amp and wire speakers to PCM4.
USB:
#38
Are you willing to share your knowledge about patching the FEC check? I'm trying to do the same for my car...
#40
#41
i should say i was planing to install Bose amplifier and complete package to macan PCM 4 and because of CP i had to change pcm4 to pcm3.1 so i can make it work .
maybe i can help you to finish your project
please check your direct messages
regards
regards
#42
Guys, I don't want to make the CP patch openly available since I am concerned that outlining how to bypass an antitheft feature could allow stolen radios to return to use. If you have IDA pro it is relatively simple to search through the strings, find the component protection function, and patch it out. You can refer to the ARM information center for the relevant instruction codes http://infocenter.arm.com/help/index...m_cegihjgh.htm. Your SW image must be dumped, unpacked, modified, then repacked to patch the system out. I have the steps to repack the root ifs with MKXFS in my Github repo. https://github.com/ibreakifix/PorschePCMStuff
Also, it certainly is possible to flash over another VAG brand MIB2 to PCM4 (for example Audi) as long as the unit has three HSD connectors (Grey, Curry Yellow and Green), but I can not provide NOR images to do so... you will need to get a Porsche PCM Display and purchase + flash the software from Porsche (9P1-906-961-E) if you want to embark on that project.
I know this is probably beyond most people's technical abilities here, so I want to keep this thread limited to talk about the PCM retrofit, I won't answer any questions or visitor messages from new members asking about patches.
#43
Hi Chris, can you maybe tell me how it is possible to update fw from audi to Porsche?
I always get variant conflict when I am trying to update the fw via sd card.
I also tried to change train Nr. In eeprom but nothing works.
#44
This seems like a lot of work to enable Carplay! I love it.
Lee Turner (06-05-2021)
#45
I'm not sure if that would solve everything, but how I would approach this if I wanted to convert variants would just be to clone the NOR and EMMC using a programmer.
