Entry and Drive locking question
I just got a 2015 Cab C4S,
When I picked up the car from the dealer I was able to exit and lock the car using the button on the driver door handle, I then personalized the settings on the keys and now I can't lock the car using the button on the driver handle, but the button on the passenger handle works and locks the car.
What did I do wrong and how can reverse that change so I can lock the car from the driver handle?
Received 3,460 Likes
Correct, one should be able to lock and unlock either door with either key in your pocket or hand. Does it not unlock the driver's door with either key?
Both handles open the car.
Passenger side button handle locks the car.
So the only problem, is that I cannot lock the car using the driver side button on the handle.
Keep us posted, which will help complete the loop.
Slightly off topic but I recently picked up a 2014 C4S with Entry and Drive and I can’t for the life of me open the Frunk by waving my hand over the crest.
Is there a specific spot or motion you’re supposed to use?
it might just be the battery. door handle lock was finicky recently and all it took was a fresh battery to get everything working fine again.
