Paddle Shifters on Steering Wheel????
Hi - I'm looking at a PDK 991S to replace (or supplement) my manual 997S as the clutch is killing my leg. At any rate, I came across this 991S that has PDK but the shifters are on the steering wheel instead of having paddle shifter. I have paddle shifters on my 458 so I'm used to actual paddles. What's the deal with this set up? I do not see it on many cars. Is it an option? Is it still a dual clutch system??? An explanation would help! Thanks!
https://my.dealersocket.com/NewEbroc...d=TgewSm69FPs=
I would be suspicious of a dealer that advertises the original MSRP of that vehicle a being $207,535.00 (see picture below) when I reality it was only $120,430.00
That is the standard wheel. Would need the sport wheel or retrofit the newer wheels for paddles. Same everything just different way to activate the manual shifting. You could either adapt to this or convert to one of the other wheels if this car checks all the other boxes for you.
That's the "multifunction" wheel. Same gearbox, just buttons on both sides of the steering wheel to shift with. Push the button on the front of the wheel, it upshifts, pull (toward you) the button from the back of the wheel and it downshifts. You can also shift with the stick -- push "up" (forward) to upshift, pull "down" (backward) to down shift.
Having owned a DCT Ferrari myself, that particular wheel will be confusing to you initially, because both buttons on the wheel do the same thing, push either the right or left one and they will upshift, unlike the paddles, where the right upshifts and the left downshifts. I have the multi-function wheel in my PDK 991 and what I eventually did was got accustomed to pushing the front button with my right hand, and pulling the left button with my left hand.
There are nice things about that wheel, primarily the ability to change the information screen in the fifth gauge or answer calls and so forth without taking your hand off the wheel and fumbling for a stalk or a button. The TechArt paddles are nice but very expensive for what they are.
The other thing that will take some getting used to is unlike the Ferrari, where the paddles are mounted to the column, as you turn the wheel in the Porsche, the paddles turn with it, so changing gears on a turn is not as intuitive. You do get used to it fairly quickly, but I'd hate to be switching back and forth a lot.
I currently have the 991.1 multifunction wheel with the “button” shifters. They actually protrude out the back of the wheel enough to give it a paddle like feel. Biggest change is that either button can shift up (push) or down (pull).
i’m still Considering a retrofit but in the end not sure it’s worth the $2k. Can think of more interesting mods for the money.
I recently swapped out my MF wheel with shift buttons to a 991.2 MF wheel with paddles. Yes, it was expensive but to me worth it. I prefer the look, feel and size of the new wheel much better. Also, I personally hated the buttons and prefer the paddles.
mfonseca - can you speak more to the size difference between your old and new MF wheels? Is it more diameter vs thickness?
I'd be much more likely to make the switch if it significantly improved the hand feel of the wheel.
Also how difficult was the swap. Did you do it yourself?
I installed it myself and it was a very easy install. The old wheel comes off very easily and the new one goes back in the same way. The GPS adapter instructions were very clear and easy to follow. The entire process took about an hour and I went very slow to make sure that I didn't miss anything. My old wheel did not have heat function so I decided not to add that functionality to the new wheel since I don't drive the car in the winter. If you want to add heat functionality I believe it adds a few extra steps.
If you are unsure stop by a dealer and sit in a 991.2 and touch and feel the wheel for yourself.
The wheel is a bit smaller in diameter. Its not a huge difference it feels better to me. Also, the old wheel the center was pretty flat with the wheel and the new wheel the center is more recessed so if just feels better. Sounds weird but it makes a difference to me. The thickness is pretty much the same between the two. The new wheel fells a slight bit thicker at the 10 & 2 positions which you can see if the picture.
Aesthetically it’s just a better looking wheel. More sporty and evocative of the 918 Spyder interior vs the current Panamera inspired look.
I swapped my wheel, too. Worth it.
