Sunroof seal adhesive
I searched a bit, but everyone seems to get this fixed under warranty...
The rubber gasket that goes around the sunroof panel has separated on the passenger side. It seats in fine and the gasket is in good repair, it just looks like the adhesive failed in that spot. Anyone know what they use for this? I was going to use some CA glue I have around, but figured I'd ask to see if anyone has experience with this first.
TIA.
TIA.
I have the exact same on my 17, .C2. Wasn't sure if it's a thing I can claim to be fixed on warranty. Is this a common problem? The thing is, it just doesn't look right, but else everything is fine. No bad whistle sounds or leaks.
There are specialty sealant/adhesives for weather stripping that you will find at your auto parts stores.
I'm sure this will be fixed under warranty. Lots of threads about it being fixed under warranty on the board.
