Installed mud flaps.. yes mud flaps.. to hopefully stop those f*%#ing rocks
Installed mud flaps today thanks to a thread in the 911 R/GT3 section by guys who’ve done this with good results. Tired of these aggressive offset HRE’s only helping that classic 911 issue of kicking up debris all over my paint, so went ahead and did it. Here’s a copy of my post from that thread:
Officially a member of the #FlapGang!
Didn’t take the wheel off, and no power drill, all by hand. Just need enough screws of different shorter lengths to use for different piercing methods (and to ensure no puncturing anything behind the liner), and a screwdriver.
I didn’t get both sides exactly alike (later had the epiphany that I could have just placed the second one backwards on top of the first one and drilled the new holes exactly the same way which would have also saved a ton of time. Oh well) and the driver side hangs a little lower than the passenger side. It kind of bugs me that maybe I set them too low hanging and they’re not precisely exact with each other, but then I think “if you’re gonna go for it, go for it” and wanted to ensure protection which letting them “hang” a bit will do.
When I told my wife I was doing this, she said “mud flaps, like a truck?” hahaha. To some people the view of some black flaps and exposed screws (that part bugs me on a Porsche, but not too much.... yet. Kind of a “durable” look I guess) is worse a bunch of tiny rock chips. But my aggressive offset HRE’s kick up so many rocks to my precious Aqua Blue paint, me and my OCD touch up paint applications to extremely small dots with toothpick tips reached its breaking point. Hopefully this alleviates that.
The way the fender now kind of “flares” at the bottom even kind of looks cool in its way.
Let me know what ya think.
NeilF (02-22-2021)
Hopefully this mitigates rocks being kicked up. Seems like it should. I assume the majority of rock damage happens from the tires flinging them from that low area, and you can see how massively exposed your tires are at the very bottom of the tapered in fenders and how much exposed bodywork is at the mercy of the area below the fenders.
The flaps are a generic $11 part from Amazon. Screwed them into the liners. A lot cheaper than wrapping the doors and fenders. Hopefully effective.
Thanks! Glad it looks clean to you guys. What's funny is although sports cars and mud flaps should be as odd as it gets, I feel they're a lot less intrusive than they'd be on an SUV or sedan. Reason being that the 911 is so low, you don't really see the flaps, and they just kind of blend in with the shadows in regards to hiding how low they "flap" since the car is already practically on the ground. On an SUV flaps are extra noticeable as they sit higher in your line of sight and are still high off the ground.
Yeah, the piece of mind is already immense. Immediately felt like a weight was lifted. Will be interesting to monitor how it works.
KA , nice job and they don't look bad either , the color of your helps to blend them into the wheel wells . Send me the link for the flaps you purchased from Amonozon and what size /type screws did u use
https://www.amazon.com/RoadSport-4406-Universal-Premiere-Splash/dp/B000CPHXQ2/ref=lp_11375110011_1_7?srs=11375110011&ie=UTF8&qid=1553945500&sr=8-7
Check out this thread as someone towards the bottom shows what's behind the liners. I kind of used the pic as a map and used small screws that I have pictured toward the bottom of this thread, as well as the standard screws that come with the flaps. No issues with hitting or rubbing anything even with the longer screws that come with the flaps, as you can push on your liner and see just have much space there is behind it. Just don't use super long screws:
https://rennlist.com/forums/991-gt3-...flaps-diy.html
Nice job!
Thanks fellas! Glad to see the reactions.
Thanks! I hear ya. The screws aspect does bug me a bit, but mostly in theory so far. I’ll know how much it does or doesn’t bug me in literal tangible physicality once I get used to seeing it in various settings, haha. The good thing is it’s easily removable, can be taken on and off, etc. The only downside I guess would be some holes in the liner which would be hard to notice unless you look hard for it, and it’s not a very expensive piece anyway. Hoping and assuming I just forget they’re there and let them provide the extra protection (i.e leave them on).
Yeah, my main issue with PPF on the sides (would have to be doors and fenders) was 1: Very expensive. And if I just do partial coverage (still pretty expensive) those visible seam lines are fairly high on the car which would drive me nuts (says the guy with the mud guards, go figure lol. But the guards look stealthy enough to where they don’t seem to bug me, at least not yet). 2: If you get a door ding, PDR becomes nearly a thousand+ dollar job as they’d have to remove the entire door or fender wrap to do it (I assume PDR would pull it right off the area of work), and then you’d have to reapply. 3: I saw a GT3 RS with the fenders wrapped and they looked like CRAP up close. The way the plastic takes a beating looks even worse than chipped paint, imo. And it can’t be touched up. 4: Still a bit paranoid it may affect the shine. But I have my whole front PPF’d and honestly it’s very hard to impossible to tell. Seems to shine just as nice and consistent as the rest of the car. More durable from swirls too.
But if money was less of an object, I’d probably just PPF all of it and spend the coin to replace when necessary, lol.
Received 5,388 Likes
12 screws for mud flaps, no problem, but we freak out at the thought of screwing on a front license plate. It's not easy being a Porsche owner.
I have PPF installed on my quarter panels. It wraps into the wheel well. I have the OEM rock guard on top of that. The seams are not noticeable. It all depends on the quality of the installer.
