Cobb released 100 octane tune for 991.2
Anybody here try it yet? If you want the map just connect the accessport to your computer and open the app. It will auto update.
I've got a custom tune on 93 octane.. Wonder how the 100 octane OTS map performs.
(i know the second i tune it i will blow something up and own a 6 figure paper weight)
Received 4,378 Likes
You guys are really drinking the Kool-Aid, yes?
There is no software "Tune" that can give you big power by going from 93 to 100 octane. To actually require that would mean you would have to alter the compression ratio of the engine by changing pistons. Higher Octane fuel actually has a lower burn, and is used to offset higher compression.
If you have a 991.2 and value your warranty in the least, you will avoid this sort of thing.
Big power? Probably not but there's an increase.
He's very knowledgeable in yesterdays cars/track racing.. I don't mean that in a demeaning way. I've read other posts by him in which he was spot on.
Have you gotten your big turbos yet? Interested to see your improved 60-130 times
Moderator's note: I edited out the above personal attack post quoted in this post.
Bigs
100 octane allows for much better cooling and better combustion especially in higher temp regions like South Fl.
100 octane enables more power through more aggressive tuning without detonation. Our engines have a conservative tune to take into account low octane and a multitude of driving conditions and styles. Factory sets limits on tables built into stock tune to preserve the engine over life of vehicle and warranty. The 100 octane tune basically allows for more timing without retard due to knock retard.(I’m sure they do more with torque tables and such as well). The other limiting factor is usually Input Air Temperature. Heat soak will also cause problems with knock retard so usually these tunes work better with improved airflow in intake, larger intercoolers, and more free flowing exhaust.
About 8 bucks a gallon. Only two stations in town have it.
I want to try it but I'd have to somehow run my tank dry to fill it up with 100.. Even then we're looking at $120 for a full tank.. Worth a try but don't want to run anything under 100 octane.
Yeah, I'm going to try it also, just want the tank basically empty. I live in Atlanta and I can't even find any in the metro area. Nearest station that has it at the pump that I am aware of is 30-45 mins one way.
