Glass Polish for windshield
My 991 has a "swipe" arch marking on the passenger's side of the windscreen from the wiper. This was realized when I purchased the car (CPO no doubt). I really can't feel it with a fingernail, but it is not coming off with glass cleaner or car wax and elbow grease. What (if any) glass polishers are out there I can use with an orbital?
Have you tried to clay it? I periodically clay my windshield and am amazed at the crap that I can see in the clay.
You need Rayon Glass Polishing Pads if you’re going to use a orbiting machine plus the CeriGlass Polish.
https://www.autogeek.net/scratch-rem...car-glass.html
0000 Steel Wool will polish (almost) anything off a pitted windshield. Start with light pressure and gently work your way up to more pressure as needed.
Warning: ONLY "0000 Steel Wool" will do.
Anything rougher WILL scratch your glass.
Received 3,365 Likes
And use it with some vinegar and keep it wet, which is what I used in the past for the same issue and it appeared to have worked just as well as any other fancy stuff.
Before you hit it with steel wool have you tried a glass polish with micro fiber pad on an orbital buffer like Griots or Zaino?
I'm sure 000 steel wool is a great last option.
