Major service-THE RIGHT WAY!
#46
I wholly agree with you. Though I may not be able to live up to the standard you're describing... I do service my 911 myself as it is my daily driver / puppy mobile and I believe nobody will give it as much care as I would. There have been two situations where I am not comfortable with doing the work myself and thus have had the good ppl at SOUL do it, but you are spot on.
#47
Great Post and so good to see a Major Service where the Inspection and Extra's are completed with care. It's not just a glorified "Oil Change" like many folks think. Big Difference!
You get what you pay for, but only when it's actually done properly.
#48
" For the roof I used Porsche's recommended grease for all of their sliding roofs. Here is the part number : 000.043.303.39
For the upper strut mounts I used high pressure grease. "
" What did you use to clean and lubricate the door seals ? "
Answer : " I used Winzer rubber restore ".
#49
I use this stuff for my sunroof, and it works like a charm:
Liqui Moly 3312 Silicon-Fett transparent, 100 g
The instructions how to do it right did I find in this video:
