991.2 4 GTS stock alignment specs?
Hi,
Does anyone have stock alignment specs for 991.2 4 GTS? not sure if it would be different to regular Carrera 4. I'm having trouble finding it online.
Thanks in advanced!
Thanks in advanced!
please anyone?
i don’t go to Porsche Service for my alignment. I go to my local tire shop. Their alignment setting has specs for 991 but it’s not specialized to type. It’s just for all carrera and I suspect it is specs for 991.1. It may be that the specs for .1 and .2 are same but I think I’m pretty sure actual specs are slightly different between versions, like carerra vs GT3. Just curious if there is a spec specific to .2 4 GTS. If no one knows, I guess my next alignment will be at Porsche Service and then I will be able to find out.
I am curious to know. Even though I will be taking in for an alignment and be told what it is when they put it on the rack, I will be going more aggresive when I do this. If I knew what it was now, I would have a better idea before hand what I want to change it to.
I got my 2017 911 Targa 4 GTS aligned today. The stock alignment before adjustments was -1 upfront and it had -2.2 on left rear and -2.4 on right rear. I had the m put the rear at -2.4 on both sides and -1.3 was the max they could get out of the fronts. The Targa GTS only has PASM so, may be able to get more on a SPASM I suppose up front. That is really aggressive for the rears on a stock car, I was suprised it was that much. Hopefully the extra .3 I gained up front will be helpful. We shall see this weekend.
Reviving this thread as it's the closest I can get in an hour of searching.
Alignment performed during service today, 991.2 GTS, and it looks like they did it for PASM not SPASM, is that what you see?
(coupe not targa, I know the targa is PASM only)
Does anyone have the stock specs for .2 4GTS / SPASM, or their own alignment results like below?
