991.1 air dam blades
I think you are looking for the Retainer Assembly - Porsche (991-505-986-00-1E0), assuming you have a "standard" front bumper cover (not SD). This part is about $134 USD and specific to Left or Right side. Also check if these "covers" are the finished parts that go on top of the retainer assembly Insert - Porsche (991-505-763-00-1E0) and Insert - Porsche (991-505-765-00-1E0). These parts are a bit better priced at around $35 USD each.You can verify with your parts counter....
Hope this helps!
Hope this helps!
Cool -- Would be good to hear from you what the DIY install procedures are, if you go that route. I am assuming you will need to take the bumper cover off, remove the existing retainers. Also, note that the "covers" are both right-and-left AS WELL AS "upper" and "lower" specific when ordering! Also, they list as "black" but not sure if they are intended to be painted, paint-ready primer or actually flat black plastic. Again, best bet is to ask for specifics from your parts source when putting an order in. Worst case you may need to paint to the color you want.
