Pollen filters
Pollen filters
anyone got instructions on replacing the pollen filter?
on is somewhere near the batter and other is under the dash I believe.
i got the set as I was getting some maintenance items
hope to replace them in future myself
The frunk one is super easy. Just remove the large black plastic cowel cover. Then remove the cover (about 5 or 6 tabs lock it in place) over the paper filter on the passanger side by the firewall.
The cabin one is easy to do, but hard to access. Move the passanger seat all the way back. Climb uner the glove box. Remover the flexible foam cover, and replace the charcoal cabin filter.
These are really straightforward to change.
The filter below the glovebox is kind of a pain to reach, though. Remove three plastic screws, remove some foam, release the tabs on the airbox and manhandle the filter into place.
The filter under the hood is dead simple. No tools required, just remove the plastic cover that stretches all the way across the car (the same one you'd remove to get to the battery). Release some tabs on the filter airbox on the passenger side and the filter just slides in and out.
I'll probably go bi-annual as I only did 4,000 miles last year
