6 Year Service - Jacksonville
Old Feb 6, 2019 | 08:52 AM
Bud Taylor's Avatar
Bud Taylor
Default 6 Year Service - Jacksonville
- Has anyone had the 6 year service done at an independent and what did you pay ?
- Does anyone have a recommended indie shop in Jacksonville Florida ?
- I may just get the PDCC bottle replaced at an independent and do the rest myself, has anyone had this done and what did you pay at an indie shop or dealership?
- For the spark plugs what brand/type came in the car from the factory ? I am sure buying spark plugs from a stealership is not a good idea ?
- Did anyone here replace the filter or pre-filter element ? My car has 8K miles on it so this seems like a waste and probably would not affect warranty claims in the future.
Old Feb 6, 2019 | 08:54 AM
CSK 911 C4S's Avatar
CSK 911 C4S
@ 8K miles.
Good Parts Source:
https://www.pelicanparts.com
Old Feb 6, 2019 | 09:47 AM
Bob Z.'s Avatar
Bob Z.
Veteran: Navy
Today is your lucky day. Use Pulse Racing: https://pulseracingservices.com/
Terry is the owner and tell him Bob Z. referred you with the 991. They are one of the best Indy shops I have ever used and Terry has quite the background. I spent the whole time at the shop with him and another mechanic while he was installing my Soul high-flow cats and I really got to know him, and I am going back to him for my PCCB installation. He has the Porsche tools and cannot reprogram them and he has does custom tunes as well.
Old Feb 6, 2019 | 09:55 AM
LexVan's Avatar
LexVan
Technically speaking, IF you had the 4-year service done (plugs, filters, oil, brake fluid).......all you are due for again is oil change and brake fluid.
For example, OE Porsche plugs (Bosch) are $17 each from Sunset Porsche.
Bud, what did you exactly have done at year #4? Then we can better direct you.
Oh, one more, don't neglect your Serpt. Belt.
Old Feb 6, 2019 | 09:59 AM
Bob Z.'s Avatar
Bob Z.
Veteran: Navy
Originally Posted by CSK 911 C4S
@ 8K miles.
Good Parts Source:
And check around for parts since Pelican is much more than places like Suncoast or Sunset.
Old Feb 6, 2019 | 10:04 AM
LexVan's Avatar
LexVan
Here are some of the part numbers involved:
Old Feb 6, 2019 | 10:44 AM
CSK 911 C4S
I normally do Non-OE. Most of the time the same parts..... just w/o the Porsche box and Pelican gives you a choice.
Old Feb 6, 2019 | 12:47 PM
Sidvicious7's Avatar
Sidvicious7
Default Bosch Spark Plugs - OEM
Here is the lowest price around for OEM Spark Plugs.
https://www.fcpeuro.com/products/por...ch-99917015190
Old Feb 6, 2019 | 01:26 PM
ClassJ's Avatar
ClassJ
Beyond fluids like oil and brake fluid, what exactly needs replacement at 8K miles? If PDCC is age dependent then fine.
Filters, spark plugs, belt etc, at 6 years old are probably all fine. These things don't go bad sitting. Plugs can go bad from many many short starts and stops but that's about it.
I would take care of any age dependent services, make sure the battery is still solid, enjoy the car, and call it a day.
Old Feb 6, 2019 | 02:51 PM
Bud Taylor's Avatar
Bud Taylor
Default 4year
The 4 year service was performed by the CPO stelaership so plugs we done but the way I read the 6 year service under additional items it list the plugs and pdcc bottle.
Old Feb 6, 2019 | 02:54 PM
Bud Taylor's Avatar
Bud Taylor
Default Warranty
Agreed but I want to protect the warranty by following manufacturers guidelines (10/100 from fidelity) in case of a catastrophic claim of some sort.
Old Feb 6, 2019 | 03:02 PM
LexVan's Avatar
LexVan
BT, but I don't see how the plugs would be needed again in just 2 short years if the plugs were already done at the proper 4 year/40K Service.
Old Feb 6, 2019 | 03:04 PM
DishoomX2's Avatar
DishoomX2
BTW, for reference, this is what was completed in the "4 YEAR SERVICE" as part my 2012 911's CPO. Prices are as of March 2017. Sorry, I wasn't sure how to make it appear in a table format.
QTY PART NUMBER DESCRIPTION UNIT PRICE TOTAL
1 948-107-222-00 OIL-FILTER INSER 36.78 36.78
1 948-107-322-00 O-RING 24.20 24.20
1 900-123-106-30 ALUM SEAL RING 3.95 3.95
9 0W40 MOBIL 1 0W-40 10.35 93.15
1 55ZERO WASHER SOLVENT 10.53 10.53
2 991-110-130-00 FILTER INSERT 66.10 130.20
1 991-573-623-00 CABIN-AIR FILTER 105.48 105.48
1 991-572-371-00 AIR FILTER 26.05 26.05
6 999-170-151-90 SPARK PLUG 33.90 203.40
TOTAL PARTS 633.74
TOTAL LABOR AND PARTS 1602.14
