Will it scrape
Old Jan 29, 2019 | 06:27 PM
ST BERNARD's Avatar
ST BERNARD
Default Will it scrape
Have a math question and need help. Entrance to my driveway is 73 inches long and has an elevation of 7 inches. I believe that is a 10% grade (?). Will a 991.2 4s with Front Axle Lift clear the driveway?
Old Jan 29, 2019 | 06:31 PM
ST BERNARD's Avatar
ST BERNARD
Sorry left out Car has Sport Design Front. Obviously I don’t have the car yet.
Old Jan 29, 2019 | 09:42 PM
Porsch's Avatar
Porsch
I think you'll be fine, but one critical question is: Can you take the incline at an angle? And, if so, what angle? Sport Design front fascia does not help you.
Old Jan 29, 2019 | 09:44 PM
Wujohn's Avatar
Wujohn
Rise over run. I am not sure I understand your numbers - are you saying that over a 73" run, your driveway has a change in elevation of 7"? If so, then this should be a 9.6% grade. I can't answer the scrape question but at least we can confirm the numbers for someone else to give feedback on.
Old Jan 29, 2019 | 09:45 PM
Bob Z.'s Avatar
Bob Z.
Veteran: Navy
The 4S does not come with the SD front bumper unless it is ordered with one. Otherwise, you will not scrape.
Old Jan 29, 2019 | 09:47 PM
Psorcery's Avatar
Psorcery
Will not scrape with FAL.
Old Jan 29, 2019 | 09:48 PM
Bob Z.'s Avatar
Bob Z.
Veteran: Navy
Or without FAL. I have surprised myself with the inclines I have gone up, and down, without scraping.
Old Jan 29, 2019 | 09:54 PM
Psorcery's Avatar
Psorcery
This is true. I have the sport design with SPASM and FAL.
Even without FAL I have been surprised as Bob Z mentioned.
Old Jan 29, 2019 | 10:04 PM
FORENN's Avatar
FORENN
My GT4 didn't come with FAL (wasn't an option). I was worried but I never needed it. Then, to play it safe, I specced my GT3 with FAL, as I thought it may be lower with a longer nose than the GT4. Again, I never needed it. Can't imagine I'll ever spec FAL again. It's big deal among the GT3 guys for resale but I doubt half of them who have it ever use it but once in a while. With a little patience and good judgment, you can take most inclines at an angle with no problem at all.
Old Jan 29, 2019 | 10:28 PM
dkhm3's Avatar
dkhm3
In Los Angeles, there are lots of crappy roads with dips and uneven driveways. My m3 has so many scraps underneath and that car is not even that low.
Old Jan 29, 2019 | 10:38 PM
ST BERNARD's Avatar
ST BERNARD
Tks for all the responses. I’m actually buying a 992s with FAL and have to decide if I can order the Sport Design Front. I used a 991.2 as an example since obviously no one has a 992 yet. I believe the ground height is similar but I will check that out. I recalculated the driveway angle and it is 11.5 degrees. I can enter at an angle going in from the Street so I think based on other people’s responses that I’m ok.
Old Jan 29, 2019 | 10:58 PM
Rennolazine's Avatar
Rennolazine
You can clear alot with the lift... more than you think. Its when u forget to turn it on thats the problem... lol
Old Jan 30, 2019 | 07:07 AM
Bobby 911's Avatar
Bobby 911
No point in doing the math until you have the 992 measurements. The car is so different from previous 911s, I wouldn’t assume figures will be the same.
Old Jan 30, 2019 | 07:37 AM
evilfij's Avatar
evilfij
SJW, a Carin' kinda guy
I scrape in my driveway without FAL in my GT3. Use it every time I drive. And the driveway is not that steep (my Elise went up without scraping).
Old Jan 30, 2019 | 09:09 AM
Bob Z.'s Avatar
Bob Z.
Veteran: Navy
Now it is time to head over to the 992 Forum.
